Help with radio - macintosh
Chempowr
76
wait is the cd player working?
you might (I'm not sure) be able to reach the back of the unit to check to see if the antenna is connected you would have to reach around the back i forget what side the antenna connection is on someone that has one out can take a look real quick
I will try a cd asap! Thank you
Chempowr
76
While you are there dig out the AUX input.
Good idea. Might as well do my boost gauge too!
Chempowr
76
The first (and easiest) thing to check is the antenna lead at the windshield. Mine fell off. I re-glued it with "Permatex 21351 Electrically Conductive Rear Window Defogger Tab Adhesive."
The GT Guys say they reject a lot of new windshields, because they arrive with the antenna lead snap button detached.
Chempowr
76
So I tried the CD player. No change. When the radio is turned on there's a humming from the sub woofer that does not change regardless of what setting (cd, radio, auxiliary). That's where I'm at.
Simon
1,230
Whatever happens consider hooking up a 3mm cord to the aux port so you can stream music gps etc from your device/phone.
ok just swing by this wknd and we will check it out
TO AWSUM
Ford GT Owner
1,506
Niceville FL
Inquisitive minds must know, what's the verdict?
he never showed up
apparently you can't give free work away :)
TO AWSUM
Ford GT Owner
1,506
Niceville FL
he never showed up
You have a big heart. Good deeds never go unpunished.
Chempowr
76
he never showed up
This Sunday? [emoji28]
sure thing just give me a little bit of heads up
