Door ajar dash light stays on
bret a ewing
301
I had the same issue with my clamshell. Drivers side latch switch was the issue. Jumped it out until I could replace it.
It is a Jaguar part, you can see the leaping cat impression on the switch. If I get a chance I will post the PN.
Best, Bret.
pauls
109
San Francisco Bay Area
Best, Bret.
Thanks Bret.
bret a ewing
301
Pauls,
The latch & switch is from a 2004 - 2007 Jaguar XJ8.
The switch part # : 2W9319A434AC
Should cost around $50.
.......well at least until the parts' houses figure out it is a FGT part. :wink
Hope this helps.
Best,
Bret.
pauls
109
Pauls,
Hope this helps.
Best,
Bret.
Thanks Bret, Paul
pauls
109
Pauls,
It is the clam shell switch. I know it is under my nose but I don't see it. It seems from what you write there is a right and left. Can you help me locate the switches? Thanks.
NorthwoodGT
1,215
Michigan
IMG_2592.jpgthe switch is the same from left to right but installs 180 degrees opposite from left to right.
it's only a $30.00 switch. it snaps up inside the clamshell latches. hope this helps
Reactions: intence
pauls
109
View attachment 47336the switch is the same from left to right but installs 180 degrees opposite from left to right.
Thanks Scott
bret a ewing
301
Scott, can you still get this part, new?
Best,
Bret.
NorthwoodGT
1,215
Michigan
yes still available (for now) Ford service PN 2W9Z-14018-AA
bret a ewing
301
Thanks Scott.
pauls
109
I finally figured it out. The problem was the clam shell as many of you had said. What I wasn't doing was when the two sides of the clam shell are latched I need to take the palm of my hand on the clam sell over both latches and push down. I don't here a click (that already happened when the shell latches). I don't hear anything. The laches were just not fully seated. Finally the annoying door ajar light is history. A big thanks to all of you for your advice!
That's why I let mine drop from 4-6". Never had a problem after that.
PS. Thanks for following up! People rarely do so.
