Close
Results 1 to 8 of 8
  1. #1
    Default Correct Engine Temperature
    What is the correct (normal) engine temperature for a completely stock 2005 Ford GT, when driving locally in 1st, 2nd, and 3rd gear in high eighties to low ninty degree outside temperature with the A/C on? My temp gauge goes to 220. Is that normal, or do I have a cooling problem? Fans come on at 220 with and without the A/C on.
    Thanks,
    Seth
  2. #2
    2005 white/blue stripe RPM217's Avatar
    Join Date
    Jun 2010
    Location
    Rye Brook, New York
    Posts
    1,284
    Default
    Quote Originally Posted by sethgt View Post
    Thanks,
    Seth
    My experience is that when the temp is that hot, or I see the gauge showing near 200, I turn on the AC and the temp immediately drops down. I think that I have to have my car programmed to turn the fans on at 200, with or without the AC being on.
  3. #3
    GT Owner/B.O.D SteveA's Avatar
    Join Date
    Dec 2005
    Location
    Sandpoint Id
    Posts
    3,500
    Default
    Completely normal. Many of us have gone into the computer and turned the fans on at around 185 degrees and this does seem to make the car run cooler, mine never gets much over 200 now.
  4. #4
    GT Owner/Vendor tmcphail's Avatar
    Join Date
    Apr 2006
    Location
    St Augustine, Florida
    Posts
    3,958
    Default
    Stock low speed fan on setting is 210 and hi speed is 228. Thru custom tuning we can set those temperatures to whatever you like. If your interested PM me I can help out with that.
    Take care,
    Mr. Torrie R. McPhail - Owner
    Unleashed Tuning
    Ford/GM/DCX SCT Custom Calibrator
    EcuTek Nissan R35 GTR Custom Tuner
    HPTuners Custom Tuner / Dealer
    2006 GT 4.5L Whipple 802WHP/667WTQ
  5. #5
    GT Owner ViperJoe's Avatar
    Join Date
    Aug 2006
    Location
    Washington Crossing, PA
    Posts
    1,307
    Default
    100 degree ambient temp and I can run at 180 all day long. Don't think it ever got anywhere near 200. Custom tune and FRPP rear exit headers though!
  6. #6
    Default
    If locally u mean side streets....it will get up to 220 fast
    In fall u can tool around locally under 200
    In summer Hop on the highway...and it will drop to 180 fast
  7. #7
    GT Owner HeritageBruce's Avatar
    Join Date
    Mar 2006
    Location
    Southern CA
    Posts
    746
    Default
    Seth,
    The first thing you should do is to replace the OEM exhaust with either the Accufab Xpipe (which I have and LOVE) or the Heffner Hpipe as either take up much less room than the OEM hunk of metal and allows the hot engine air to flow out of the back of the car much easier, another popular mod is put spacers behind the license plate frame. Do a search and there are plenty of discussion on these two topics. Once you get the the fan to come on sooner (preferably with a tune at the same time), you will not have any heat issues for any kind of street driving, and most amateur level track outings.
  8. #8
    GT Owner MNJason's Avatar
    Join Date
    May 2010
    Location
    Twin Cities
    Posts
    1,978
    Default
    WaterWetter helps as well.
    2005 white
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
